Hi, I just installed GS on OS X Yosemite 10.10.5 and does not boot. It keeps trying to start and nothing. I tested GS 6.9.6 beta 4 and GS 6.9.5 and in both cases no luck
Any updated or solution?
cheers
Can you please open the Console utility (it’s under /Application/Utilities) and try to re-start GarageSale.
Maybe there’s something logged to the Console, which could give us clue what’s going on.
Ilja
