Hi there.
Recent purchaser of GS7 upgrade after using GS6 for some time. I’d be grateful for your advice and feedback on best practice on using GS7 in a template-free way; that is, not applying a built-in or purchased template, but dropping in HTML/CSS from an external listing template.
I am aware of the template designer, but I’d like to use external CSS frameworks to make the listing look a certain way. I can achieve all this from the eBay manual listing approach, but I’d very much like to use GS7 to do the same.
Broadly, I would like to:
- open GS7
- create a new listing for a SKU
- de-apply the default template, leaving no styling at all
- apply styling and content (text, external images etc) from HTML I’ve written outside of GS7
- fill in the item listing details
- list it
Is such a thing possible outside of making a template in the GS7 designer? If so, I’d be grateful for a pointer on the best/recommended approach for getting this done.
Thank you in advance.
