You should be able to continue to use it. What usually happens is with no continued support it becomes dysfunctional over time. Ebay changes rules and stipulations and without updates it may stop altogether.
I’ll use it while I can but have scaled back my EB activities so subscription no longer fits my needs,
PM
What said is correct, although I suppose officials are now spending their deserved holidays. You can of course continue using GS7, you are not obligated to switch to GS8. It will work as it worked until today (unlimitedly), and that will do at least until eBay won’t change crucial functions…
Will items RELISTED inside GS count in the 50 limit? What about created with GS but auto-relisted by EBay? What if I use GS for two different ebay accounts - 50 each or 50 total? (It doesn’t hurt to ask ) thanks
I need to research what our implementation on this is. I believe once you hit 50 on any of the accounts authorised in GarageSale, it will require a Pro subscription.
