I would like to create my own custom templates and preferably start by studying and existing one and duplicate it.
https://manual.iwascoding.com/gs7/en/Miscellaneous-Creating_Own_Listing_Designs.html
By browsing the GarageSale’s folders with the terminal, I remember having seen some .xhtml (or .html) files that had the name of existing templates.
However, I cannot remember where they were located and cannot find them again.
I browsed:
/Applications/GarageSale/...
and
/Users/Username/Library/Containers/com.iwascoding.garagesale7/Data/Library/Application Support/GarageSale/...
but cannot find the templates again.
I have created the DesignTemplates folder with the purpose to store my custom templates, but of course it is empty.
Nota Bene: I dont’ plan using the Design Utility as I’m the kind of guy who like coding (X)HTML with a code editor.
Thank you for your support.
