Starting later this year, eBay will require all images that are embedded in the listing description to use the encrypted HTTPS protocol instead of plain HTTP.
If you are using your own image server with GarageSale via FTP or webDAV, please make sure that your server is supporting HTTPS requests for your images resources.
If your server already supports HTTPS requests, makes sure the the “Download URL” field in GarageSale’s configuration for your server starts with ‘https:’ instead of ‘http:’, so you are compliant with the new rules once eBay decides to enforce it.
GarageSale’s free image hosting will embed images via HTTPS with the next beta version of GarageSale 7.0.8.
