Hi, I posted about this issue a few weeks ago and paused working on it.
I’ve had no luck importing videos through garage sale. Someone suggested I use Imovie and add an image which I tried, when adding the video GS immediately prompts me to add a title, when I do I clock OK and the same prompt comes up, it will keep asking me to to add a title, but when I add a description and click upload video the app crashes. This happens every time. Am I doing something wrong or is the app just not capable of adding videos? The file I’m using is super a small mp4 : 4.4MB
dimensions are 1280x720 … the image I’m using is also small 648x792 pixels.
Could really use help here
I just tried it here: I selected a video and in that panel I also entered a Title and Description. After hitting “Upload video” the upload process started as expected.
Could you post a screenshot where exactly you are trying to enter a title so we can see what you see?
It also might be that there is an issue with your video file. Does it play properly in QuickTime Player?
Hi, thanks for the response, yes it works fine in quicktime player:
Here are some screenshots, the first is the crash window, the second is the last step before the program crashes, the third is the “get info” screen for the video file, the last is the screen before i bounce the video from iMovie and the last one … including the last two in the next message
At first glance the video format looks fine to me.
Can you sen us the crash report, please? (paste it into a Text Edit file)
It also might be helpful if you could send us some system logs. Here’s what to do:
• Open the “Console” application (from the Utilities folder inside your Applications folder).
• Depending on your macOS system you might have to click on “Start streaming”.
• Try to start GarageSale and to reproduce the issue. This will should print some output to the Console. You might want to click on “Stop” to stop logging at this point.
• Copy the GarageSale logs. You can use the search field in the toolbar of the Console window to filter for relevant messages by entering “GarageSale”.
• Open the “TextEdit” application and paste in the copied logs into a new plain text document.
• Save the text document and attach and post it here so we can investigate further.
did you reproduced it with the Alpha version as I asked you to do? As these reports does not help to understand the issue and are not able to reproduce the crash here.
Hi, Yes the version you sent to me. 9.8a5 (1664) I reproduced the crash. again and attached is the console record. Is there is different way you would like the report to be sent?
Does is send to you automatically? Please let me know if there’s anything more i can do to help.
from the logs I can only guess what the issue is. But at least it seems to be unrelated to the video import/upload. Can you please make sure that your account(s) are all up to date? Can you please try to refresh the token(s) and trade to reproduce this issue?
Thanks, That was the issue, the program was not linked to my ebay account. Doh! Sorry about that. My first time using the program.
Should I go forward using this alpha version you had me download?
