I have never worked with Apple Scripts (or Apple prior to GS).
Who can write me a script to output the address of every order to a text or csv file?
Preferably with the fields separated.
Thanks, David
Thanks, David
In Order Mode:
Select “Export Orders” from the “File” menu to export all selected orders to CSV.
https://manual.iwascoding.com/gs8/en/Order_Section-Exporting_Orders.html
Maybe that already helps.
Thanks kristian.
I had completely forgotten about that.
