I already loaded GS9 but it seems like it didn’t load all the images from GS7.
How do I manually or redo the import database in GS9?
Is there a way to just move folders manually?
Thanks
Thanks
To do a full re-import of your library, you have to completely remove your current GarageSale 9 library from your Mac. Here is how to do that:
