How do I check when my monthly allowance renews or how many listings I have left? I havent listed anything in over 2 weeks however its saying I have used my monthly allowance of 50 items ?
You can check your listing count in the GarageSale preferences > Pro.
If you think you incorrectly get that “Maximum Listing Count Reached” message, it often already helps to restart your Mac and router.
If this won’t help, it might be required to renew the eBay token completely:
