Hi there.
Where did the checkbox go for ‘export individual files’ , when you export more than one template?
I would l ike this option for version 7x, I don’t see it.
Hi Scott,
you also export multiple listings at once. If you hold down the option/alt key while invoking the “Export Listings” command, each selected listing will be written to a separate file.
Source:
https://manual.iwascoding.com/gs7/en/Listings_Section-Exporting_Listings.html
Thanks for explaining , I didn’t read the manual yet for 7x.
