Hi All - hope someone can help.
I run some large variation listings which have up to 200 different items variations - which are very popular listings.
The range is expanding and I add new variations to them on a frequent basis.
The issue I face is as follows:-
- Before adding new variations - I first of all have to ensure that the quantities for the existing variations are in line with remaining stock; as when the listing is amended this drives the remaining quantities on Ebay. If I amend the stock levels in the inventory section this doesn’t seem to automatically feed through to the Variations section.
- To keep the stock levels correct I am having to manually look at all my remaining quantities on Ebay (for up to 200 variations) and then amend the quantities in the variations section; which is incredibly time consuming - If I wasn’t adding new variations then this wouldn’t be a problem
Has anyone found a way around this?
Is there a way to automatically update from Ebay first and then add the new variations and re-download to Ebay?
Thanks
