Hi everyone. I’m trying to create a smart group that would show all listings that were created X number days ago, i.e. I want to see which listings are not selling. Ontop of this I want to filter by number of watchers and number of views in the last 30 days. All this information is available on eBay site but none of it is available as filter values in smart group in if GS. Is there a way to do it or does GS just not support this level of integration with eBay? Thanks!
Ah, yes, I missed “Number of Watchers” and “Number of Views”. But without “Start Date” or even better “Running for Days” values available in the smart group filtering options, I can’t work out the group I want. Sorting by end date does not really work. And I don’t understand why such values are not present, they are available in eBay UI and via API. Thank you for the suggestion though!
Because there are no replies from GS support, I guess this means that they really do not support “start date” or “days from start” filtering values. Unfortunately. This is a really simple thing, data is already provided by eBay, and I don’t get it why it’s not supported.
I think you can get what you are asking for by using “days remaining” and check the box descending or not descending.
Thank you for the suggestion, but it does not work for fixed price listing because they are restarting every 30 days resetting this value. I want to see listing that were hanging around for 100 days still there were started. This data is known to GS, I can see it in each listing property in GS, I don’t understand why GS does not expose it in this smart group filtering options.
