Anyone knows a way to create a smart group that does not show deleted listings? When I use “ended unsuccessfully” status filter it brings up everything including the ones that I have deleted already, and I wanted to see only not deleted but ended manually. Thanks!
There is currently no way to filter out deleted listings via smart group rules.
If you don’t want to erase the deleted listings (by emptying the trash bin) you could simply tag them and then filter that specific tag color in your smart group settings. Just a rough idea.
Yep, I did exactly this as a temporary workaround. Would be nice to add this option. Search has an option to ignore deleted listings already. Thanks!
