How to revise a listing with lot size?
I have a lot of books I listed and forgot to go into the Advanced tab and select the Lot Size - so it defaults to 0. I’ve changed it in GS to 6, but no matter what properties I pick in the “revise selected properties”, I can not get it to update the lot size. I was able to do “revise entire listing”, but with my slow connection that takes a while. Is there a trick to revising lot size or do I need to revise the entire listing when I make that mistake in the future?
Thanks.
Sometimes GS(or Ebay has trouble picking up the change) has problems updating quantities in lot size. The fastest way I have found is to end the listings and restart them with the correct quanty. With 10,000 free listings available for me with my store level it is no problem but if you don’t have that many free this will cost you fees. Having said that, I have had some limited success tripping it back and forth from 1 to 6 or going with 20 or 100 and then back down to the actual number.
