If I buy a design from the design store, can I make changes to it and then save it with the changes that I made? I want to be able to apply this changed design to existing eBay listing templates. I don’t want to apply the design to a template and use that template as a master to start new listings with.
Sorry, the source code of purchased designs cannot be edited.
However, you can make some edits by using the given options in the “Properties” Inspector.
