Is it possible to split a string when using the script editor window? I tried using str.split() function, but it seems like the split() function isn’t enabled for strings.
Instead of rewriting my description template using the awkward markup I though I would use the script editor instead. My template is quite complex and being able to use Javascript would solve a few issues I have with the markup and be much cleaner.
Thanks. I found a better way to do what I needed. But I will test this anyway. It’s possible I did something wrong, I’m usually programming in things other than Javascript.
