Just tried to use scheduler in latest beta, which previously I’d had no problems with, but for some reason it seems to be failing, any way to see the failure reason? ( I went and started the item manually with no problem after it failed )
Can’t find any way to see anything but the triangle exclamation mark to indicate a failure.
Also trying to start a new scheduler event with multiple items selected is only adding the first one to the event, I’m sure in previous betas this was adding everything selected.
Further the countdown to next launch does not seem to then advance and continue counting down. Though on waiting, the next item did actually launch correctly, just the countdown timer was not correctly updating, and is continuing to not update though further launches appear to be working correctly.
The first item failed to automatically launch on two attempts.
