I’ve done something incredibly stupid and cannot figure out how to undo it.
When I select multiple listings, I then see them in the right hand part of the screen as small thumbnails. These are now massive and I cannot figure out how to get them back to normal size. I’m using a Mac and I don’t think its anything I’ve done through the OS as other applications are opening and displaying normally. Also the other parts of GS, such as creating listings, menus, etc are not zoomed in.
The attached screenshot shows the issue.
Any help would be appreciated!
