So, about 50% of my relists are getting the above error message.
They are all re-lists, so obviously they worked fine 7 days ago; and
There is a condition in every single listing.
Is this eBay or GS that’s causing my latest heartburn?
Version is 7.0.8b4(799)
It might be that the eBay category data are out of date. Try to update them and if done re-select the condition value.
This happens when you show item condition in the item specifics. eBay only wants to see the condition in the separate area. Go to the item specifics, scroll down til you see item condition and delete it. It should work then
