I'm trying to make a listing for multiple copies of the same item
not sure where to enter the info, example I have 10 Widgets that I’m selling for $1.00 ea.
where and how do Iist that info instead of creating 10 listings for the same thing???
If you wish to sell multiple copies of the same item, just enter the quantity in the “Quantity” field in the Options Inspector.
Hope this helps,
Kristian
ok don’t laugh but is this where i need to put the TOTAL qty on hand ?
will it automatically start a new listing or continue the listing till all the inventory is depleted?
Screen Shot 2020-06-12 at 12.05.52 PM
The Lot Size on the Advanced tab is if you are selling 10 widgets together for one price. To sell 10 individual units of 1 type of widget, use the Quantity on the Options tab.
Thank you just one more question:
if i enter a qty of 10 does the listing automatically sell only 1 ea.
then does the listing stay active till the total qty is depleted?
sorry about this just want to make sure before i give it a go.
Screen Shot 2020-06-12 at 2.30.16 PM
