Hello,
Getting a weird bug in Garage Sale 7.0.18, when I drag and drop an image into the editor window it changes the orientation of it.
It does it with all the images I add in not a massive problem just an annoyance.
Anyone else getting this?
Hello,
I had that issue much time ago. Opening all images and saving them again fixed it for me and it never happened again, but I suppose it was due to taking photos with phone camera, now I only use scanners…
Yeh but shouldn’t have too just spent a good 30 mins going through them all to make sure they are the correct orientation, but oh well lesson learned.
This might be just a quick trick to avoid this waste of time, anyway I suggest you to send GS team one of your photo so luckily they will be able to reproduce and fix the issue.
Hey Garage Team if you need an image let me know
Have never seen this before.
I noticed it when I imported photos into Mac photo app and rotated them within the app. Apart this, I never had this issue since I don’t use photo app…
After playing about some more I noticed that even tho the orientation shows as incorrect when I open up the image in the built in markup editor its the correct orientation, so guessing it’s just a bug displaying the wrong orientation.
