Importing a single listing from ebay
Unfortunately deleted my photos from GS as I was trying to clean up space….Tried to import a single ended listing - used advance and the exact time the listing ended - however got a string of listings with totally different dates and times. Tried it again with a new listed listing with the starting date - again a lot of listing from a month ago.
What am I doing wrong?
Do you maybe find that specific listing if you do not use the “Advanced” settings?
You still can sort by start date, end date or even item ID. Maybe that makes it easier for you to find the listing.
I use the ebay web site to find exact the listing(s) I’m looking for to narrow it/them down and get the date and go from there to GS to narrow the search
I did use advanced setting and gave the exact info - tried all three methods . When using the date and time I got listing for a month long period and various times BUT not the time I specified
When I need to find a specific listing on eBay (for example, to end it because it’s not in my local GS database), I always use the Active search box from the Seller Hub and find it relatively painlessly:
https://www.ebay.com/sh/lst/active
I note there’s an equivalent search at
https://www.ebay.com/sh/lst/ended?status=UNSOLD_NOT_RELISTED
(I’ve put the URLs here as tt text because when you paste in a “login required” URL it renders poorly in discourse; just cut-and-paste the text)
I can find the listing on ebay but cannot import it to GS database
Sorry; I lost the thread somehow!
I find I can’t usually use the Import from eBay dialog simply because it takes a half hour to load the data :frowning:
