Hello,
Firstly, Great Job with the New GS7! love it, Had a few issues, but the guys sorted them with updates… so great work guys!
My Question is this.
Is there a way of running a report too add up your total in-stock value using your inventory, so add up the cost of your stock in total ?
For instance, if my inventory showed the below, it would produce a report showing how much I have in stock ( £23.95)
5 Keyrings @ £3.99
2 Pens @ £1.50
1 Ruler @ £1.00
Many thanks for this, If there is not this feature, is it possible too add it in? as i think a lot of sellers would use this?
Many thanks in advance
Steve - UK
(Hope Ive got this in the right place, this is my first time using a Forum)
