Does anyone else have problem with loading photos? I use iPhoto and it takes forever to open. I am on an older MacBook Pro, but, I just upgraded to GarageSale 7 and it takes MUCH MUCH LONGER for the photos to open and load into the listing. Drag and drop doesn’t work either.
Thanks in advance
Yes - I am having the same problem.
I can no longer drag and drop photos and it’s taken about 10 minutes for GS to even get to my iPhoto folders.
I’ve been tinkering with it for a while. No breakthrough yet.
Are you really referring to “iPhoto”? Apple replaced it with “Photos” that’s why I am asking.
Here is a GREAT user tip. iPhoto WILL drag and drop into GS7. Photos will NOT! Apple removed drag and drop when the latest system came out last year. I use IiPhoto daily because I can drag and drop and ignore the photos because it won’t drag and drop.
A great way to speed up importing from Photos under macOS 10.13 goes like this:
- in Editor mode (pencil icon), click the ‘+’ below the images column
- Choose “Add Image File…”
- in the ‘Open’-panel, choose “Media” > “Photos” in the left most column
- the contents of the Photos library is available almost instantly
My GS shows this when I click on the +.
Sorry, I missed a step. Original post updated.
Sorry, found it at the bottom. Way to many steps. Drag and drop is much faster
Yes, thank you, I am not sure about the person who initially started the thread, but I definitely meant Photos. Great catch.
This worked for me. Thank you, Ilja.
If I have all my photos in an album I can drag them into a desktop folder which will allow drag and drop into GS.
THe first step can be tediously slow though.
