I understand that the maximum number of images that GS will support is 20.
And that eBay will allow 12.
Can they be combined so that I can create a single listing with 32 images? And if so, how would I do that?
Thanks
Nick
PS
I realise that external hosting with unlimited images is also an option but want to see if I can make the above work.
TNS
August 25, 2019, 9:11pm
#2
I don’t think that will work, but I’ve been proven wrong before.
Sorry, you can’t do this but with the upcoming GarageSale Pro up to 50 images(!) can be insterted into the item description.
I had a feeling that may be the case!
It is only occasionally that I have a listing where I need to go above 20 images. When Pro comes out, will I be able to ‘upgrade’ just for the months when I need a high number of images?
Thanks
Sure, you can use it whenever needed. Cancelling it is just one button click.
system
Closed
September 5, 2019, 10:07am
#6
