I understand you guys are busy and it is not a priority but did this item get on your to do list?
The “Display listings with/without issues” feature doesn’t work for you?:
https://manual.iwascoding.com/gs8/en/Listings_Section-Starting_Listings.html#dealing-with-errors-and-warnings
(scroll down there to the last paragraph/screenshot)
Does not work for me, no. If I deselect either choice, everything disappears from the window’s list view.
To be honest, I had forgotten that the display options were there - or are they new?
Anyway, as with @Vaguery, they do not work.
When working they would be ideal.
Do these 26 listings failed with warnings (yellow icon) or with errors (red icon)?
Here are a couple of examples:
One other thing. The Seller profiles message often appears and it is in fact a furphy and has nothing to do with the reason the item did not list.
Hi David,
I think, if I remember correctly, you can right-click on THAT warning, and select “ignore all future warnings like this one”…
Thanks @Neal I know that is a useful function but I want to know the items which failed to list so I can list them again. Usually it is just a comms issue between Ebay and GS that causes the listing failure.
Yes, though it is also sometimes a change in the terms and/or Attributes fields. For instance, some time back I had a lot of Lego listings which all suddenly demanded a “Character” field be set, and I had to manually discover the failures and warnings and set that field to “None” (for a bag of plain white blocks, for example).
