GS7 b47
The “Listing Designs” pane is now empty. None of the included free designs or the two purchased designs show up. Only pop-up choice is ‘All’. Pane shows completely empty. No designs.
Can access the design store. Can re-download the two paid designs. Still nothing shows. Preferences >> ebay >> New Listings >> the pop-ups for ‘Design:’ and ‘Layout:’ show the included designs, but not 2 paid designs. New eBay listings honor the preference defaults, but cannot be changed, and if deselecting the checkbox [x] ‘Don’t use a design’ then it is impossible to reassign a design.
Reinstalled GS7 b47.
Also removed ~/Library/Preferences/com.iwascoding.garagesale.plist.*.
No effect and they were not recreated.
Last Mod 2016.03.24 so probably not current preference storage mechanism.
Design Templates are still present: GarageSale/Contents/Resources/DesignTemplates/
Paid Templates are still present: ~/Library/Containers/com.iwascoding.garagesale7/Data/Library/Application\ Support/GarageSale/PaidDesigns (with mod time of re-download)
Please advise.
