I have just started using GarageSale. Is there a simple way to transition my old eBay listings into the GarageSale format without ending the listing in eBay and starting over? I can’t seem to find anything in the manual on this.
how about the “import from My eBay” command?:
http://wiki.iwascoding.com/mediawiki/index.php?title=File_Menu#Import_from_My_eBay
Thank you! One more question. I am little confused about templates. Once I list an item, can I delete the template or will it affect my ability to edit the item in the future? Also, can I delete the listings that were initially downloaded under the heading “Imported from My Ebay” when I initially set up GarageSale. Or will this remove the listings from eBay? I am still getting my feet wet on this so some things confuse me.
If you delete the template, you are making it hard to revise a running listing made from that template. So it would keep the template around until the listing has expired.
Yes, you can delete these listings if you want to. Deleting a listing template in GS does not effect the running listing on eBay.
The current template/listing paradigm in GarageSale dates back to a time, when it was indeed possible to have several similar listings online at the same time. Since that’s not possible anymore because of eBay’s duplicate listing policy, GarageSale 7 will only have listings, which should simplify things.
I am having this same issue. I have worked out how to bring in my existing eBay store listings (prior to Garage Sale), but they don’t have my fancy template like the ones that I am using in the new listings that I am putting on Garage Sale. How can I get them to look like my others on Garage Sale once I have imported them in?
Hi mindy,
in Editor mode activate the “Design” checkbox if not activated already and select a listing design afterwards.
Does this help?
