Hello,
today after the update, all the listing is empty. If I add something in the search module the listings appeared…
Hello,
Hi JSB,
this seems to be an issue with your GarageSale database, unfortunately.
GarageSale has a repair mode implemented that you should give a try. Please follow these steps to enable it:
Hope this helps,
Kristian
Thank you, it works.
But I still have the synching problem… Maybe it’s because my total “container files” is more than 340Go.
