I started my first auction (#141857057365) and GarageSale says that it is uploaded but I can’t find it in eBay when searching for key words or even when looking directly at the category(s). I suppose it might take some time to be visible in search results - but even when looking directly at the category? How long might it take to be visible? Or is there some eBay setting that might make my own listing invisible to me? I’m afraid that I’ve done something wrong and nobody else will see it either. Thanks for any help.
It took several hours but it is finally visible. Thanks anyway.
E-bay say it can take up to 24 hours! However you should be able to find the listing if you look via ‘my e-bay’ ‘Active sales’ even if it’s not showing up in a search.
