I’m having some trouble and would like to delete ALL of garage sale 8x (preferences etc etc) and do a clean install. The ONLY thing I do NOT want to delete is (of course) the folder with all my listings. Can someone tell me the name/location of that folder so that I can trash over other item and try again to solve some issues? Thanks!
What you could do is to export all your listings, then make the clean install and import the listings afterwards.
FAQ #26 describes how to delete your GarageSale database:
https://www.iwascoding.com/GarageSale/Support.html#FrequentlyAskedQuestions
(Be aware, this will delete your complete database! Make sure you have a backup.)
Do you maybe want to describe what problems you have first? Maybe there’s an easier solution.
thank you, I’ll give it a try
I refresh the account token, but still get the message “there’s no account token”
Where is the access token stored? Because I am having problems with my keychain, so could it be related?
It might be required to renew the eBay token completely:
If this won’t help, please give this a try:
- Quit GarageSale if running.
- Open the macOS “Keychain Access” application and enter “GarageSale eBay Account” in the search field. (If you don’t find anything try it with “ebay token”.)
- Right-click on the eBay account token in the Keychain and select “Delete”.
- If done, restart your Mac, start GarageSale and add/refresh your eBay access tokens in the GarageSale preferences > Accounts.
Source: FAQ #14
