Hi there. A while back, I turned-off Coverflow (i.e, design templates carousel) and cannot figure out how to get it back. Many thanks!
There should be an almost invisible divider at the upper border of the window in GarageSale 6. If you place your mouse there, click and drag towards the bottom of the window, you should be able to get the CoverFlow view back.
