Note: I’m a developer and running the Tahoe beta on my laptop (not 100% smart). These may not be bugs in GarageSale at all! But rather than let them pile up, I’m just going to take a little spare time while things are updating and make some notes. Most users probably should ignore, and probably the devs should also ignore until the Public Beta comes out ![]()
- The Search box in the toolbar works fine as long as I stay in the Listing view. If I switch to the Orders view, it disappears and the toolbar adjusts to fill the missing space, and never comes back, though the magnifier dropdown still is visible but grayed out (and not functioning). Need a restart of GS to get it to return. [GS 9.2.2 + Tahoe beta 8] Result: I cannot use search except in the Listing view.
