Is there a quick way to re-list all my items in CDN$ ? Currently my items are all in US$.
Thanks
Thanks
If you’re referring to GarageSale 6: You can switch to CDN$ in the currency settings in the Advanced Inspector (scroll down there).
Thanks for the prompt reply. Unfortunately when I do what you suggest & then “revise current listing” I get an error message from eBay - “Currency is unchangeable when revising or relisting an item.”
It’s not possible the change the currency of a running eBay listing. I guess, you have to cancel the listing and re-list with US$ as currency.
But my understanding of the ebay.ca currency change is, that you can leave your old CDN listings running, only new listing are barred from using CDN as a currency.
How do I change multiple listings currency with garage sale 7?
You can bulk-edit multiple listings at once. Please see the help here for all details:
https://manual.iwascoding.com/gs7/en/Listings_Section-Bulk_Editing.html
However, if I am not mistaken you can only change the currency if the selected eBay site supports multiple currencies. You can check it in the Advanced Inspector in the “Location” options.
