Im using v8.0.3 and when I right click on an image and select Markup nothing happens. Any idea what might be causing the problem ?
Please let us know which version of macOS you have installed.
Also, can you please give the latest beta version of GarageSale 8.0.4 a try?:
Thanks very much for the quick reply.
I’m using OSX 10.15.1 Catalina
Will try the Beta later.
Hi Kristian,
I’ve successfully installed 8.0.4b2 and the inability to use the markup still remains I’m afraid.
Sorry, it seems that the Markup feature in GarageSale is broken under MacOS Catalina. We have to check if a work-around is possible.
Thanks for letting me know, I’ll keep an eye on any updates.
I’m having the same issue with markup tool
