The moving Groups now works except when I do something stupid like move it to itself. GS9 hangs at this point and has to be force quit. Whilst it does restart it still has those items noted somewhere but not visible.
In the image below, The item in red was that which I had attempted to move. I created a new copy of it using a different template, deleted it and then emptied the trash. GS thinks it is there though and hangs when I select it.
I have a fix for the original issue, which will be included.
For correcting the fallout from the original bug, could you send me your GarageSale.leveldb directory as a .zip file somehow, if the size of if the zip file permits a transfer via Dropbox or something similar.
Any luck with this Ilja? One of those items appeared in the Activity Window today and froze GS. I now have about many hundreds of items that were re-listed by eBay because GS could not stop them. Is there anyway to relink them?
Would you please make this a priority. GS is almost unusable because of the issue.
It cause GS to hang no matter what other operation is in place. Its ok if I am watching but otherwise is causing me a lot of grief. Every time it hangs it probably means that eBay will be out of sync with GS.
