Multiple choices of item - is it possible?
Up to now I have only used GS for single items.
Is it possible to use GS also for basically the same item but e.g. different size, color etc. (in the same auction)? I didn’t find it in the manual.
Thanks.
yes, sure, GarageSale supports “variations”!
If supported by the selected category you can add them in the “Advanced” Inspector.
Please see the help here:
https://manual.iwascoding.com/gs7/en/Listings_Section-Variations.html
There’s a video tutorial available, too.
