I am relatively new to GarageSale 7. For the most part I am really impressed by it.
One problem I keep having is that my cost for certain items will not stay. I can put a price and a cost in for an inventory item, look at something else, go back to that inventory item and the price and cost are gone! It does not say that it was 0.00, but the fields are blank.
I have been trying to figure out a pattern so I can avoid the problem, but so far I have not found one. Any suggestions?
ilja
February 20, 2017, 3:27pm
#2
What version of GarageSale, and what version of macOS are you using?
Also, when the prices disappear from the inventory item, do you see anything that looks like an error logged from GarageSale to the Console utility (under /Applications/Utilities)?
For GarageSale, I am using 7.0.6 (791).
I am running MacOS Sierra 10.12.3.
I have not tried looking at the logs right after a price disappears. Often, I don’t realize that the price and cost have disappeared until I am listing the item on eBay and I am decided what I need to make based on my original cost. The next time it happens for a new item I will take note of the time and look in the logs.
Here is what happens when I attempt to add the price and cost to an existing item where the price and cost always disappear. I added the price and cost, went a couple of fields past them, went to a different item, then came back to verify that the price and cost had disappeared.
default 09:48:26.426715 -0600 GarageSale TIC TCP Conn Cancel [4561:0x608000b9a000]
default 09:48:26.427057 -0600 GarageSale __nw_socket_service_writes_block_invoke sendmsg(fd 22, 85 bytes): socket has been closed
default 09:48:26.744453 -0600 GarageSale 0x60001147a140 opened /var/folders/1x/tfhw5dcj2k51mj0bwvyyjm600000gn/C/com.iwascoding.garagesale7//mds/mdsObject.db: 4636 bytes
default 09:48:26.744521 -0600 GarageSale 0x60001147a140 closed /var/folders/1x/tfhw5dcj2k51mj0bwvyyjm600000gn/C/com.iwascoding.garagesale7//mds/mdsObject.db
default 09:48:26.745100 -0600 GarageSale 0x608014a67380 opened /var/folders/1x/tfhw5dcj2k51mj0bwvyyjm600000gn/C/com.iwascoding.garagesale7//mds/mdsDirectory.db: 50744 bytes
default 09:48:26.745186 -0600 GarageSale 0x608014a67380 closed /var/folders/1x/tfhw5dcj2k51mj0bwvyyjm600000gn/C/com.iwascoding.garagesale7//mds/mdsDirectory.db
default 09:48:26.745476 -0600 GarageSale 0x608011479480 opened /Users/georgemoseley/Library/Keychains/login.keychain-db: 753340 bytes
default 09:48:26.745713 -0600 GarageSale 0x608011479480 closed /Users/georgemoseley/Library/Keychains/login.keychain-db
default 09:48:26.747226 -0600 GarageSale loading /Users/georgemoseley/Library/Keychains/login.keychain-db
default 09:48:26.749523 -0600 GarageSale 0x608014876640 opened /Library/Keychains/System.keychain: 57204 bytes
default 09:48:26.749631 -0600 GarageSale 0x608014876640 closed /Library/Keychains/System.keychain
default 09:48:26.751197 -0600 GarageSale loading /Library/Keychains/System.keychain
default 09:48:41.753807 -0600 GarageSale 0x60801407ca80 opened /var/folders/1x/tfhw5dcj2k51mj0bwvyyjm600000gn/C/com.iwascoding.garagesale7//mds/mdsObject.db: 4636 bytes
default 09:48:41.753909 -0600 GarageSale 0x60801407ca80 closed /var/folders/1x/tfhw5dcj2k51mj0bwvyyjm600000gn/C/com.iwascoding.garagesale7//mds/mdsObject.db
default 09:48:41.754472 -0600 GarageSale 0x608000869080 opened /var/folders/1x/tfhw5dcj2k51mj0bwvyyjm600000gn/C/com.iwascoding.garagesale7//mds/mdsDirectory.db: 50744 bytes
default 09:48:41.754558 -0600 GarageSale 0x608000869080 closed /var/folders/1x/tfhw5dcj2k51mj0bwvyyjm600000gn/C/com.iwascoding.garagesale7//mds/mdsDirectory.db
default 09:48:41.754849 -0600 GarageSale 0x608003a68240 opened /Users/georgemoseley/Library/Keychains/login.keychain-db: 753340 bytes
default 09:48:41.755139 -0600 GarageSale 0x608003a68240 closed /Users/georgemoseley/Library/Keychains/login.keychain-db
default 09:48:41.756894 -0600 GarageSale loading /Users/georgemoseley/Library/Keychains/login.keychain-db
default 09:48:41.759361 -0600 GarageSale 0x608011c62b40 opened /Library/Keychains/System.keychain: 57204 bytes
default 09:48:41.759439 -0600 GarageSale 0x608011c62b40 closed /Library/Keychains/System.keychain
default 09:48:41.761053 -0600 GarageSale loading /Library/Keychains/System.keychain
default 09:48:41.764203 -0600 GarageSale TIC TCP Conn Start [4562:0x600000192550]
default 09:48:42.175607 -0600 GarageSale TIC TCP Conn Event [4562:0x600000192550]: 1 Err(0)
default 09:48:42.175654 -0600 GarageSale TIC TCP Conn Connected [4562:0x600000192550]: Err(0)
default 09:48:42.175831 -0600 GarageSale TIC Enabling TLS [4562:0x600000192550]
default 09:48:42.284881 -0600 GarageSale TIC TLS Event [4562:0x600000192550]: 2, Pending(0)
default 09:48:42.285003 -0600 GarageSale TIC TLS Event [4562:0x600000192550]: 11, Pending(0)
default 09:48:42.285644 -0600 GarageSale TIC TLS Event [4562:0x600000192550]: 22, Pending(0)
default 09:48:42.285810 -0600 GarageSale TIC TLS Event [4562:0x600000192550]: 12, Pending(0)
default 09:48:42.285879 -0600 GarageSale TIC TLS Event [4562:0x600000192550]: 14, Pending(0)
default 09:48:42.293609 -0600 GarageSale TIC TLS Trust Result [4562:0x600000192550]: 0
default 09:48:42.418763 -0600 GarageSale [0x7faf1e576600] Created session
default 09:48:42.419908 -0600 GarageSale [0x7faf22467400] Created session
default 09:48:42.420992 -0600 GarageSale [0x7faf1e5e0c00] Created session
default 09:48:42.422050 -0600 GarageSale [0x7faf1e4e9000] Created session
default 09:48:42.423063 -0600 GarageSale [0x7faf1e21d400] Created session
default 09:48:42.424077 -0600 GarageSale [0x7faf1e4d0200] Created session
default 09:48:42.449335 -0600 GarageSale TIC TLS Event [4562:0x600000192550]: 20, Pending(0)
default 09:48:42.449794 -0600 GarageSale TIC TCP Conn Event [4562:0x600000192550]: 8 Err(0)
default 09:48:42.449824 -0600 GarageSale TIC TLS Handshake Complete [4562:0x600000192550]
default 09:48:42.469929 -0600 GarageSale [0x7faf1e4d0200] Decoding: C0 0x008000A0 0x0008304A 0x22111100 0x00000000 6400
default 09:48:42.469979 -0600 GarageSale [0x7faf1e4d0200] Options: 1x-1 [FFFFFFFF,FFFFFFFF] 00054060
default 09:48:42.470273 -0600 GarageSale [0x7faf1e4d0200] Decoding completed without errors
default 09:48:42.470663 -0600 GarageSale [0x7faf1e21d400] Decoding: C0 0x008000A0 0x0008304A 0x22111100 0x00000000 6586
default 09:48:42.470692 -0600 GarageSale [0x7faf1e21d400] Options: 1x-1 [FFFFFFFF,FFFFFFFF] 00054060
default 09:48:42.470903 -0600 GarageSale [0x7faf1e21d400] Decoding completed without errors
default 09:48:42.471218 -0600 GarageSale [0x7faf1e4e9000] Decoding: C0 0x008000A0 0x0008304A 0x22111100 0x00000000 5131
default 09:48:42.471243 -0600 GarageSale [0x7faf1e4e9000] Options: 1x-1 [FFFFFFFF,FFFFFFFF] 00054060
default 09:48:42.471424 -0600 GarageSale [0x7faf1e4e9000] Decoding completed without errors
default 09:48:42.471724 -0600 GarageSale [0x7faf1e5e0c00] Decoding: C0 0x008800A0 0x0009304A 0x22111100 0x00000000 9998
default 09:48:42.471748 -0600 GarageSale [0x7faf1e5e0c00] Options: 1x-1 [FFFFFFFF,FFFFFFFF] 00054060
default 09:48:42.472012 -0600 GarageSale [0x7faf1e5e0c00] Decoding completed without errors
default 09:48:42.472278 -0600 GarageSale [0x7faf22467400] Decoding: C0 0x008000A0 0x0008304A 0x22111100 0x00000000 14169
default 09:48:42.472300 -0600 GarageSale [0x7faf22467400] Options: 1x-1 [FFFFFFFF,FFFFFFFF] 00054060
default 09:48:42.472606 -0600 GarageSale [0x7faf22467400] Decoding completed without errors
default 09:48:42.472909 -0600 GarageSale [0x7faf1e576600] Decoding: C0 0x00A00080 0x000A304A 0x22111100 0x00000000 5906
default 09:48:42.472934 -0600 GarageSale [0x7faf1e576600] Options: 1x-1 [FFFFFFFF,FFFFFFFF] 00054060
default 09:48:42.473143 -0600 GarageSale [0x7faf1e576600] Decoding completed without errors
default 09:48:42.477567 -0600 GarageSale [0x7faf22066c00] Releasing session
default 09:48:42.477686 -0600 GarageSale [0x7faf1c40f600] Releasing session
default 09:48:42.477797 -0600 GarageSale [0x7faf1c080200] Releasing session
default 09:48:42.477903 -0600 GarageSale [0x7faf1c5d6200] Releasing session
default 09:48:42.478046 -0600 GarageSale [0x7faf1c6bee00] Releasing session
default 09:48:42.478151 -0600 GarageSale [0x7faf1c787000] Releasing session
default 09:48:42.478276 -0600 GarageSale [0x7faf1c07aa00] Releasing session
default 09:48:43.693012 -0600 GarageSale [0x7faf1ca0a000] Created session
default 09:48:43.694743 -0600 GarageSale [0x7faf22066c00] Created session
default 09:48:43.696082 -0600 GarageSale [0x7faf22006000] Created session
default 09:48:43.697282 -0600 GarageSale [0x7faf22492000] Created session
default 09:48:43.699604 -0600 GarageSale [0x7faf22494c00] Created session
default 09:48:43.701744 -0600 GarageSale [0x7faf1c319e00] Created session
default 09:48:43.702959 -0600 GarageSale [0x7faf1c07aa00] Created session
default 09:48:43.745084 -0600 GarageSale [0x7faf1c07aa00] Decoding: C0 0x00A000A0 0x000A304A 0x22111100 0x00000000 9189
default 09:48:43.745126 -0600 GarageSale [0x7faf1c07aa00] Options: 1x-1 [FFFFFFFF,FFFFFFFF] 00054060
default 09:48:43.745436 -0600 GarageSale [0x7faf1c07aa00] Decoding completed without errors
default 09:48:43.745797 -0600 GarageSale [0x7faf1c319e00] Decoding: C0 0x00A000A0 0x000A304A 0x22111100 0x00000000 10816
default 09:48:43.745820 -0600 GarageSale [0x7faf1c319e00] Options: 1x-1 [FFFFFFFF,FFFFFFFF] 00054060
default 09:48:43.746080 -0600 GarageSale [0x7faf1c319e00] Decoding completed without errors
default 09:48:43.746373 -0600 GarageSale [0x7faf22494c00] Decoding: C0 0x00A000A0 0x000A304A 0x22111100 0x00000000 10581
default 09:48:43.746397 -0600 GarageSale [0x7faf22494c00] Options: 1x-1 [FFFFFFFF,FFFFFFFF] 00054060
default 09:48:43.746659 -0600 GarageSale [0x7faf22494c00] Decoding completed without errors
default 09:48:43.746912 -0600 GarageSale [0x7faf22492000] Decoding: C0 0x00A000A0 0x000A304A 0x22111100 0x00000000 9725
default 09:48:43.746942 -0600 GarageSale [0x7faf22492000] Options: 1x-1 [FFFFFFFF,FFFFFFFF] 00054060
default 09:48:43.747187 -0600 GarageSale [0x7faf22492000] Decoding completed without errors
default 09:48:43.747443 -0600 GarageSale [0x7faf22006000] Decoding: C0 0x00A000A0 0x000A304A 0x22111100 0x00000000 11072
default 09:48:43.747465 -0600 GarageSale [0x7faf22006000] Options: 1x-1 [FFFFFFFF,FFFFFFFF] 00054060
default 09:48:43.747812 -0600 GarageSale [0x7faf22006000] Decoding completed without errors
default 09:48:43.748138 -0600 GarageSale [0x7faf22066c00] Decoding: C0 0x00A000A0 0x000A304A 0x22111100 0x00000000 10141
default 09:48:43.748162 -0600 GarageSale [0x7faf22066c00] Options: 1x-1 [FFFFFFFF,FFFFFFFF] 00054060
default 09:48:43.748413 -0600 GarageSale [0x7faf22066c00] Decoding completed without errors
default 09:48:43.748664 -0600 GarageSale [0x7faf1ca0a000] Decoding: C0 0x00A000A0 0x000A304A 0x22111100 0x00000000 17678
default 09:48:43.748686 -0600 GarageSale [0x7faf1ca0a000] Options: 1x-1 [FFFFFFFF,FFFFFFFF] 00054060
default 09:48:43.749036 -0600 GarageSale [0x7faf1ca0a000] Decoding completed without errors
default 09:48:43.753426 -0600 GarageSale [0x7faf1e576600] Releasing session
default 09:48:43.753558 -0600 GarageSale [0x7faf22467400] Releasing session
default 09:48:43.753668 -0600 GarageSale [0x7faf1e5e0c00] Releasing session
default 09:48:43.753777 -0600 GarageSale [0x7faf1e4e9000] Releasing session
default 09:48:43.753880 -0600 GarageSale [0x7faf1e21d400] Releasing session
default 09:48:43.753987 -0600 GarageSale [0x7faf1e4d0200] Releasing session
default 09:49:13.447452 -0600 GarageSale TIC TCP Conn Cancel [4562:0x600000192550]
default 09:49:13.447914 -0600 GarageSale __nw_socket_service_writes_block_invoke sendmsg(fd 22, 85 bytes): socket has been closed
Bump the bumping thread to the bump bump bump.
ilja
February 23, 2017, 2:54pm
#5
Unfortunately that log didn’t included any clues.
If this only is happening with a single inventory item, my guess is that something is wrong with that very item. I suggest you copy all relevant info to a new inventory item and delete the old one.
It is happening to a number of inventory items, not just one.
I am happy to delete the items, but how can I reuse the SKU that I used for those items.
ilja
February 24, 2017, 3:10pm
#7
Once you deleted an inventory item, and emptied the trash in the inventory section, you should be free to re-use the SKU in a new inventory item.
Please try this with a single inventory item first, and see if the error indeed goes away.
system
Closed
March 6, 2017, 3:10pm
#8
