I am trying to create an auction on the USA site and cannot choose the 'See description for shipping terms" item…it is grayed-out. Why is this, and what can I do to choose it?
Thanks, Walt
Thanks, Walt
Hi Walt,
it seems that this option is not supported by eBay USA. Are you sure that you can select “see description” if you go through the eBay sell your item form?
Kristian,
Sorry to be so tardy in replying. You appear to be correct…this is not an option on US site. Funny, tho…it used to be available and I used it often in my ads.
Thanks for the reply and for the great product!
Walt
