<Package Type is Missing> error (shipping) persists
Submitted this before. Edited shipping profile on eBay, no luck. Created new profile, no luck. Re-installed GS 9.5.5, no luck. Updated token, no luck. Only way around this so far is to edit the listing directly on eBay, which creates confused situation. Really would like to solve this. This occurs when trying to revise an existing listing, modifying the shippiing profile to be used.
If I skip using profiles and create the shipping prefs without using profiles, I’m able to modify the listing.
Thanks, – james
did you choose you package type from this drop down menu?
Is it any better with this version?
https://downloads.iwascoding.com/downloads/GarageSale_10.0b10.dmg
