I have some legacy listings that I need to update the payment instructions (There used to be a text box you could edit in the payment options). That is no longer there - is there another way to access it so I can delete the text? I can list the items, it’s just that I get the warning message “Payment Instructions are not supported for eBay-managed payments”
You can remove the deprecated payment instructions from your legacy listings by just running the following script:
// Find and delete Payment Instructions
function run(){
consoleLog("\nListing Title: '" + listing.title + "'");
if (listing.paymentInstructions) {
consoleLog("• Payment instructions found: '" + listing.paymentInstructions + "'");
// Delete payment instructions:
listing.paymentInstructions = "";
consoleLog("• Payment instructions deleted!");
else {
consoleLog("• No payment instructions found.");
Insert that script in GarageSale script editor window and hit the “Run” button.
(Select Show Script Editor Window from GarageSale’s Window menu to open the script editor.)
