Downloadied v8.0.3 and am not able to list because it states I need to specify a PayPal address, however my PayPal address is already input in Preferences. Help, please. Thanks so much.
Oops, I am using v. 8.0.5, not 8.0.3. Sorry about that.
This might be an issue with your eBay token.
Please give this a try:
If this won’t help, please let me know.
Having same issue with specifying PayPal address . Tried steps as outlined . no luck
Please give this a try then:
Quit GarageSale if running.
Open the macOS “Keychain Access” application and enter “GarageSale eBay Account” in the search field and press return afterwards. (If you don’t find anything try it with “ebay token”.)
Delete the eBay account token from the Keychain.
If done, restart your Mac, start GarageSale and add/refresh all your eBay access tokens in the GarageSale preferences > Accounts.
Hope this helps,
Kristian
Thank you so much for your time . It worked !
