Hi - I am using Version 9.1.1 - this morning I opened my library folder to clean out some old cached images. I removed about 10K of them like I usually do every few weeks. I emptied the trash folder and then when I went back to work on new listings, I tried to grab a listing and move it and it would not move. GarageSale closed on me, then said I need to reimport database, which I did - I did NOT select start with a blank library - and now all my listings are gone.
Ive recovered any files I may have deleted by accident using DiskDrill and dragged them in again to the library folder but nothing comes up.
I have 50 hours of work to do in the next 24 hours if I cannot get this to work, Im begging you for a fix here
thank you for a fast reply in advance.
OK, so I had a thought - I went to the time machine backup for yesterday for the GS library folder and I copy pasted it and saved it to a new folder. I can just delete the current one which is seemingly corrupt at this point from whatever I did and paste the old one in there, right?
So far I haven’t deleted the wrong file or had to restore after deleting the wrong file. My mac has 3.5 TB of space and I have used less than 1 TB. That is a lot of room. I keep 1 listing of every sale and when I list a new one the old gets deleted so my file isn’t growing that fast.
