No worries. Uploading a 3GB file over standard internet line just takes that long.
Ok. Good.
Can you tell me if it’s uploaded? I went to sleep around 3:00 and it was at 22%. Came down this morning and I can’t tell whether it did or did not finish.
(I have started uploading it again in case it didn’t go.)
Sorry, doesn’t look like the file made it through. Can you give it another try?
Ok.
(Sorry. It wants more words before it will let me post.)
Ok. It’'s at 84%. and I’m going to trust that it makes it the rest of the way.
Good night.
Thank you so mutch. I see the file on Dropbox now. Will download and check it today.
Yay!
The listing is called:
1938 Printing of “Our Shelter” by Josephine Worthington & Catherine Frank
Can you please give this version a try and check if it lets you export a listing without producing an insanely huge file:
http://downloads.iwascoding.com/downloads/GarageSale_7_2017-01-23_3.dmg
Why, yes! 26,908 bytes (29 KB on disk).
Can you please also check if the preview now works again for those listings, where it previously didn’t?
Sadly, it doesn’t show previews for those which were previously not showing.
No, it doesn’t.
Michelle Anderson
207.447.8028
Â
Â
Â
