I am stuck trying to create new listings with garagesale as every listing comes up HTTP error due to our paid design using HTTP link and not HTTPS.
I have gone through all the posts to try to resolve including bulk editing through ebay for already active listings, updating our garagesale to latest version and going through the repair image links option but still have an error can anyone shed any light on how I can resolve this?
did you actually revise the listings in question using GarageSale’s Revise function?
Also, are you using GarageSale 7.0.9?
If you select “Show Design Templates” (Window menu) and scroll down to the “Pro: Classic” entry what version number is shown there?
It should be “2.6”. If it’s an earlier version clicking on the Download button should update it.
Did you purchase this design in GarageSale 6 or in GarageSale 7?
I’m having the same issues with my ProAir template on all of my new listings. I re-downloaded the template and I’m on version 2.6 of the template. I’m running the latest version of GarageSale. Any help is appreciated.
Did you actually revise the listings in question using GarageSale’s Revise function?
Hi Kristian, as I mentioned I’m running the latest version of GarageSale. I purchased the design quite some time ago so it might have been GarageSale 6, is there a way I can tell? I’m confused as to why I need to “revise the listing” as I’m referring to brand new listings that I’ve just created within the updated GarageSale using the updated template.
Please provide me with a link to the listing.
Could you export the listings in question using GarageSale’s export function (File menu > Export Listings) so I can have a closer look at it?
Hi Kristian, thanks for your continued response. I reset all of the parameters of the template and I’m still getting the https warning. I played around with other templates and they seem to be fine so at this point I am not going to waste any more time with ProAir and I’m just going to use another template. Perhaps when I get home from work tonight I will play with it further and send you the listing.
