Hi there,
I am having a problem with my pro design template. I bought it on my laptop, and I did all my work there. But now, I would like to edit templates on my iMac, so after exporting those, I find out that my iMac does not load the template, just the free ones, which I do not use. How I can work with the paid template on a new station, thank you!
This should do the trick:
On your iMac open GarageSale 7 and simply select “Show Design Templates” (Window menu). In that window click on the cart icon in the toolbar and enter the transaction ID to re-download your design(s).
If you no longer have the transaction ID, please contact the support.
Also, this only works if you use the same GarageSale license on both Macs.
Thanks, I will try that! ️
