Dear Ilja,
thank you for the quick answer. I downloaded the beta version. I did not replace the previous version, so now I have two GarageSale aliases.
After starting the Beta, I tried to import a generated xml-file with 99 image-links.
Spinning ball do not stop spinning… GS hang up.
So I have to kill GS.
Console shows this:
08.01.18 15:29:14,391 com.apple.appkit.xpc.openAndSavePanelService[10844]: Error in CoreDragRemoveTrackingHandler: -1856
08.01.18 15:29:14,391 com.apple.appkit.xpc.openAndSavePanelService[10844]: Error in CoreDragRemoveReceiveHandler: -1856
08.01.18 15:29:14,702 GarageSale[10842]: html preview for item: COLLECTION XYZ,
08.01.18 15:29:24,262 CalendarAgent[314]: [com.apple.calendar.store.log.caldav.queue] [Got error on refresh, but not rectifying principal because it was manually configured: Error Domain=CoreDAVHTTPStatusErrorDomain Code=401 “(null)” UserInfo={CoreDAVHTTPHeaders=<CFBasicHash 0x7fe122c01190 [0x7fff7aeef440]>{type = immutable dict, count = 13,
entries =>
0 : Content-Type = <CFString 0x7fe122d879f0 [0x7fff7aeef440]>{contents = “application/vnd.google.gdata.error+xml; charset=UTF-8”}
1 : Vary = <CFString 0x7fe122d84780 [0x7fff7aeef440]>{contents = “Origin, X-Origin”}
3 : Alt-Svc = <CFString 0x7fe1245c1750 [0x7fff7aeef440]>{contents = “hq=”:443"; ma=2592000; quic=51303431; quic=51303339; quic=51303338; quic=51303337; quic=51303335,quic=":443"; ma=2592000; v=“41,39,38,37,35"”}
5 : Content-Encoding = gzip
6 : Server = GSE
7 : X-XSS-Protection = <CFString 0x7fe122d3ea70 [0x7fff7aeef440]>{contents = “1; mode=block”}
8 : Expires = <CFString 0x7fe124510760 [0x7fff7aeef440]>{contents = “Mon, 08 Jan 2018 14:29:24 GMT”}
9 : Transfer-Encoding = <CFString 0x7fff7a9b2f50 [0x7fff7aeef440]>{contents = “Identity”}
12 : Cache-Control = <CFString 0x7fe122d4a300 [0x7fff7aeef440]>{contents = “private, max-age=0”}
13 : Date = <CFString 0x7fe122d92ef0 [0x7fff7aeef440]>{contents = “Mon, 08 Jan 2018 14:29:24 GMT”}
19 : X-Content-Type-Options = nosniff
21 : X-Frame-Options = <CFString 0x7fe122d4c160 [0x7fff7aeef440]>{contents = “SAMEORIGIN”}
22 : Www-Authenticate = <CFString 0x7fe122d0cf00 [0x7fff7aeef440]>{contents = “Bearer realm=“https://accounts.google.com/”, error=invalid_token”}
08.01.18 15:29:24,268 CalendarAgent[314]: [com.apple.calendar.store.log.caldav.queue] [Account refresh failed with error: Error Domain=CoreDAVHTTPStatusErrorDomain Code=401 “(null)” UserInfo={AccountName=Google, CalDAVErrFromRefresh=YES, CoreDAVHTTPHeaders=<CFBasicHash 0x7fe122c01190 [0x7fff7aeef440]>{type = immutable dict, count = 13,
entries =>
6 : Server = GSE
08.01.18 15:29:24,277 CalendarAgent[314]: [com.apple.calendar.store.log.caldav.queue] [Coalescing failed operation [<CalDAVAccountRefreshQueueableOperation: 0x7fe122d81d10; Sequence: 0>]]
08.01.18 15:29:25,332 CalendarAgent[314]: [com.apple.calendar.store.log.caldav.queue] [Got error on refresh, but not rectifying principal because it was manually configured: Error Domain=CoreDAVHTTPStatusErrorDomain Code=401 “(null)” UserInfo={CoreDAVHTTPHeaders=<CFBasicHash 0x7fe1278258e0 [0x7fff7aeef440]>{type = immutable dict, count = 13,
entries =>
0 : Content-Type = <CFString 0x7fe124700260 [0x7fff7aeef440]>{contents = “application/vnd.google.gdata.error+xml; charset=UTF-8”}
1 : Vary = <CFString 0x7fe124706310 [0x7fff7aeef440]>{contents = “Origin, X-Origin”}
3 : Alt-Svc = <CFString 0x7fe12470a000 [0x7fff7aeef440]>{contents = “hq=”:443"; ma=2592000; quic=51303431; quic=51303339; quic=51303338; quic=51303337; quic=51303335,quic=":443"; ma=2592000; v=“41,39,38,37,35"”}
6 : Server = GSE
7 : X-XSS-Protection = <CFString 0x7fe12473ccc0 [0x7fff7aeef440]>{contents = “1; mode=block”}
8 : Expires = <CFString 0x7fe124715ec0 [0x7fff7aeef440]>{contents = “Mon, 08 Jan 2018 14:29:25 GMT”}
12 : Cache-Control = <CFString 0x7fe124790150 [0x7fff7aeef440]>{contents = “private, max-age=0”}
13 : Date = <CFString 0x7fe124746280 [0x7fff7aeef440]>{contents = “Mon, 08 Jan 2018 14:29:25 GMT”}
21 : X-Frame-Options = <CFString 0x7fe12470a500 [0x7fff7aeef440]>{contents = “SAMEORIGIN”}
22 : Www-Authenticate = <CFString 0x7fe1247263f0 [0x7fff7aeef440]>{contents = “Bearer realm=“https://accounts.google.com/”, error=invalid_token”}
08.01.18 15:29:25,337 CalendarAgent[314]: [com.apple.calendar.store.log.caldav.queue] [Account refresh failed with error: Error Domain=CoreDAVHTTPStatusErrorDomain Code=401 “(null)” UserInfo={AccountName=hermesphila@googlemail.com, CalDAVErrFromRefresh=YES, CoreDAVHTTPHeaders=<CFBasicHash 0x7fe1278258e0 [0x7fff7aeef440]>{type = immutable dict, count = 13,
entries =>
6 : Server = GSE
08.01.18 15:29:25,346 CalendarAgent[314]: [com.apple.calendar.store.log.caldav.queue] [Coalescing failed operation [<CalDAVAccountRefreshQueueableOperation: 0x7fe12407abb0; Sequence: 0>]]
08.01.18 15:29:28,231 MEGAShellExtFinder[10845]: host connection <NSXPCConnection: 0x7fc313724090> connection from pid 10844 invalidated
08.01.18 15:29:28,232 com.apple.xpc.launchd[1]: (com.iwascoding.garagesale7.58272[10842]) Service exited due to signal: Terminated: 15
08.01.18 15:29:30,569 spindump[455]: Saved hang report for GarageSale version 7.0.11b1 (820) to /Library/Logs/DiagnosticReports/GarageSale_2018-01-08-152930_Alexanders-MacBook-Pro.hang
08.01.18 15:30:36,357 CalendarAgent[314]: [com.apple.calendar.store.log.caldav.queue] [Got error on refresh, but not rectifying principal because it was manually configured: Error Domain=CoreDAVHTTPStatusErrorDomain Code=401 “(null)” UserInfo={CoreDAVHTTPHeaders=<CFBasicHash 0x7fe122d1a910 [0x7fff7aeef440]>{type = immutable dict, count = 13,
entries =>
0 : Content-Type = <CFString 0x7fe122cd5f80 [0x7fff7aeef440]>{contents = “application/vnd.google.gdata.error+xml; charset=UTF-8”}
1 : Vary = <CFString 0x7fe12440e420 [0x7fff7aeef440]>{contents = “Origin, X-Origin”}
3 : Alt-Svc = <CFString 0x7fe124716720 [0x7fff7aeef440]>{contents = “hq=”:443"; ma=2592000; quic=51303431; quic=51303339; quic=51303338; quic=51303337; quic=51303335,quic=":443"; ma=2592000; v=“41,39,38,37,35"”}
6 : Server = GSE
7 : X-XSS-Protection = <CFString 0x7fe124721850 [0x7fff7aeef440]>{contents = “1; mode=block”}
8 : Expires = <CFString 0x7fe122c0bb20 [0x7fff7aeef440]>{contents = “Mon, 08 Jan 2018 14:30:36 GMT”}
12 : Cache-Control = <CFString 0x7fe122cfbcf0 [0x7fff7aeef440]>{contents = “private, max-age=0”}
13 : Date = <CFString 0x7fe12440d270 [0x7fff7aeef440]>{contents = “Mon, 08 Jan 2018 14:30:36 GMT”}
21 : X-Frame-Options = <CFString 0x7fe124726760 [0x7fff7aeef440]>{contents = “SAMEORIGIN”}
22 : Www-Authenticate = <CFString 0x7fe122cd2d40 [0x7fff7aeef440]>{contents = “Bearer realm=“https://accounts.google.com/”, error=invalid_token”}
What else could I try?
Thanks for your help.
Best regards
Alexander
