Once again, every one of my listings has a red exclamation mark graphic next to the PayPal fields.
And once again, I have to try to remember what to do when this happens.
The error message says the PayPal address is missing. But it isn’t. I went to GS → Preferences and could see it. But I removed it and put it back in just for good measure. Nothing.
I hit the “eBay Access Token” as well as the “Account Details: Update Account Details” in Preferences.
Then I went to click on the sprocket and can’t find it.
Please tell me where the sprocket is and what else I need to do to hundreds of my listings.
At first, please give this a try: Click on the PayPal field in the GarageSale preferences > Accounts, press Command-A followed by the Delete key and re-enter the data.
What you also should check is if you have selected a payment profile in the payment options. If you have, it might be that the profile uses out-dated PayPal settings.
Hello,
i have the same problem
I tried to reenter the paypal address in the account preferences but without success.
I do not have any payment or other profiles.
If I remove the payment option with paypal I can not put ads online, the buttons can not be selected.
Thank you for your help
Im using garage sale 7.0.9 version
Cyril
Hi, ALL IS OK NOW
I DO THIS:
I am sorry you still have trouble.
Can you please give this another try?:
Open the GarageSale preferences > Accounts.
Remove your eBay account by hitting the minus button at the bottom.
Restart GarageSale 7.
Re-add your eBay account in the GarageSale preferences > Accounts.
If this still won’t help can you please check your account settings on the “My eBay” website and make sure that your PayPal account is connected with your eBay account there?
Hi Kristian
I tried everything I could think of including re-adding Ebay token but in the end what worked was I added my Ebay account again in the settings (so had two accounts listed, one as default) then deleted the default account. This seemed to force a re-sync and it worked.
