I am trying to modify and create a new template in the Design and Utility program, but even though I create or modify the templates, they are not being updated or added in GS.
which version of GarageSale/Design Template Utility are you using? Which version of GarageSale is selected in the Preferences panel of the Design Template Utility?
Regards,
Version 4.0b2 (401) - Gs 9.3 - Any Version
This is an outdated version and not compatible with GarageSale 9. Please try this version:
https://downloads.iwascoding.com/downloads/DesignUtility_5.0.dmg
Regards,
Great, it works perfectly! For the next time, where can I find the download version of DESIGN UTILITY?
You can find the download link to the latest version in the help chapter here:
https://manual.iwascoding.com/gs8/en/Miscellaneous-Creating_Own_Listing_Designs.html
