Hi everybody
As all of you, i sell on ebay and i got my own 5500+ listings ebay shop.
I’d like to know if there is any possibility in the inventory section to put the place where each single article is located in my “Garage”, because i can’t remember every single place.
Till now i’ve used Danea Easyfatt combined with Turbolister, but now i moved to IOS system and i can’t use them anymore.
Thank you in advance for your support.
Best regards, Giuffrida Alberto
Ciao Alberto,
the best way is to write it at the end of the title. Otherwise, you can use the private note (avanzate>commento privato). In my opinion private note would be the best way, but with a massive quantity of listing it is a bit long to switch every time to advanced tab (and, most of all, remember to write it every time… in title it is much more useful also for looking for good thought ebay)
Good Idea, many thanks
